AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Block attribute and visibility state
0 REPLIES 0
Message 1 of 1
337 Views, 0 Replies
Hi everyone,
I have create a valve and I attach the actuator as an annotation (the command "convert to control valve" doesn't satisfy me).
To let me to change the actuator type I have create a block with different visibility state and it works perfectly (while PID symbols delete dynamic block command, annotation keep these things).
Now I have to list the valve with theyre actuator.
To do this I have add a parameter to my valve call "actuatortype" and I read it in my actuator block using an attribute. To change the visibility state I crate a table in my actuator block that match the value of the attribute and the visibility state.
It works!
The problem is that after changing the parameter actuator type value the table update but not the visibility state, to do this i have to click on the table manually but I want to underline that the table update correctly.
Someone know how solve (if it is possible) it?
0 REPLIES 0
”Boost
