I'm using P3D 2014 Ext.2.
I can extend a 3/4" pipe from the center of the blind flange without issue, but I cannot connect a 3/4" male plain end (MPE) valve to the blind flange. My valve has an end code of PL, which is the same as the pipe, so I was thinking it should work.
The only way I've been able to do it is to first place a sockolet on the flange, but that's not how we do it.
Is it just a connection setting I need to adjust?
Picture below shows an o'let I'd like to remove.
I would like to know also. We use the gate olet type valves that do not require an olet.
I should have updated this thread. Below is the result I received from offline support on the issue.
"Our development team has confirmed this as an issue. They are currently looking to see if a fix can be provided in a future release or update."
