can anyone tell me how to set blind flange prefixes same as flanges, currenly it show as 1,2,3 and so on... want to change to F1,F2,F3 and so on.....
Through the normal project setup this is not possible and I am not aware of where in the IsoConfig.xml this might be configured. I will check on this though and see if this is possible by editing the xml. In the mean time the workaround would be to manually edit the text once the Iso is created.
Quentin Contreras
Technical Support Specialist
By default blind flanges are annotated only by the part number.
You want to add a prefix (e.g. 'BF') to the part number in blind flanges annotations.
Here is what you need to add in the isoconfig.xml file
To solve this task you have to configure the isoconfig.xml-file of your iso style. Follow these steps:
Quentin Contreras
