AutoCAD Plant 3D General
Message 11 of 28 (507 Views)
Re: BUG when using PLANTPARTCONVERT in Plant 2014
05-06-2013 03:07 PM in reply to: TomislavGolubovic
I used EXPLODE command and got "could not be exploded". Where am I wrong?
Anatol D. Gutak
Employee
TomislavGolubovic
Message 12 of 28 (502 Views)
05-06-2013 03:10 PM in reply to: agutak
Is it still named as a block now? if not, make it a block
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
Message 13 of 28 (500 Views)
05-06-2013 03:13 PM in reply to: TomislavGolubovic
It's still a block reference. What should I do?
Anatol D. Gutak
Employee
TomislavGolubovic
Message 14 of 28 (496 Views)
05-06-2013 03:13 PM in reply to: agutak
so now try the PLANTPARTCONVERT
Tomislav Golubovic
Autodesk, Inc.
Message 15 of 28 (490 Views)
05-06-2013 03:21 PM in reply to: TomislavGolubovic
I tried the PLANTPARTCONVERT - nothing.
But I can't explode the block and then create a new one, as you suggest, because I'm getting "could not explode".
And additionaly after applying the PLANTPARTCONVERT I got in command line:
Specify port location:
Modeling Operation Error:
     Length negative or zero.
But I did all the same as in previous Plant 2012, 2013
Anatol D. Gutak
Message 16 of 28 (463 Views)
05-06-2013 04:37 PM in reply to: agutak
After playing with all this I finally exploded it into pieces, created a new block as was suggested and tried the PLANTPARTCONVERT. But I haven't got any good results from it, the problem remains the same. There are no connection ports in my model after PLANTPARTCONVERT...
Anatol D. Gutak
Employee
TomislavGolubovic
Message 17 of 28 (451 Views)
05-06-2013 06:54 PM in reply to: agutak
just as a test, if you draw a cylinder, make it a block, then do plantpartconvert, does that work?
Tomislav Golubovic
Autodesk, Inc.
Message 18 of 28 (448 Views)
05-06-2013 07:14 PM in reply to: TomislavGolubovic
I've just reinstalled Plant 3D.
Even with a simple cylinder I have zero conection ports!
I can put this cylinder into Spec Editor, but with zero ports
Anatol D. Gutak
Employee
TomislavGolubovic
Message 19 of 28 (435 Views)
05-06-2013 07:54 PM in reply to: agutak
Hmmm, well that ain't right is it.
Did you do a repair and a full reinstall? Does it work if someone else logs onto that machine? Your Windows profile might be corrupted?
Tomislav Golubovic
Autodesk, Inc.
Message 20 of 28 (433 Views)
05-06-2013 08:02 PM in reply to: TomislavGolubovic
I made a full reinstall.
I've tried to make conversion on two different machines with x32 and x64 under administrator and user on both. So the problem isn't here.
Anatol D. Gutak
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
