AutoCAD Plant 3D General
Member
diegorgfaria
Message 1 of 4 (282 Views)
BOP Tag
282 Views, 3 Replies
04-09-2012 09:28 AM
Is there a way to customize a tag format in order to show the BOP in an Ortho View?
I tried to create a new tag format, but I couldn't find the parameter on the "Select Class Properties" box under Pipe (attached file).
TIA.
Product Support
jason.drew
Message 2 of 4 (231 Views)
Re: BOP Tag
04-16-2012 02:21 PM in reply to: diegorgfaria
Using "Position Z" would get you close, but that's the COP elevation.
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Employee
Message 3 of 4 (213 Views)
Re: BOP Tag
04-18-2012 10:54 AM in reply to: jason.drew
Please see this discussion entry. It may be what you're looking for:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Elevation-in-ORTHOVIEW/td-p/3172994
Peter Quinn
Senior Product Manager
Member
diegorgfaria
Message 4 of 4 (196 Views)
Re: BOP Tag
04-20-2012 11:11 AM in reply to: PeterQuinn
Thanks for the replies.
I consulted the provided link, but my problem is a bit different. We have already modeled the entire project, and, if I'm not mistaken, the routine in the link works for new elements or elements modified after the creation of the triggers.
Is there a similar solution to update all the Pipe Run Components (or just pipes actually) that we've already created?
Regards.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
