AutoCAD Plant 3D Forum
BOP Tag
3 REPLIES 3
diegorgfaria
612 Views, 3 Replies
BOP Tag
Is there a way to customize a tag format in order to show the BOP in an Ortho View?
I tried to create a new tag format, but I couldn't find the parameter on the "Select Class Properties" box under Pipe (attached file).
TIA.
3 REPLIES 3
jason.drew
in reply to: diegorgfaria
Using "Position Z" would get you close, but that's the COP elevation.
Jason Drew
Designated Support Specialist
PeterQuinn
in reply to: jason.drew
Please see this discussion entry. It may be what you're looking for:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Elevation-in-ORTHOVIEW/td-p/3172994
Peter Quinn
Senior Product Manager
Autodesk, Inc.
diegorgfaria
in reply to: PeterQuinn
Thanks for the replies.
I consulted the provided link, but my problem is a bit different. We have already modeled the entire project, and, if I'm not mistaken, the routine in the link works for new elements or elements modified after the creation of the triggers.
Is there a similar solution to update all the Pipe Run Components (or just pipes actually) that we've already created?
Regards.
”Boost
