AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Autocad Plant 3D 2012
10 REPLIES 10
Message 1 of 11
batone79
1312 Views, 10 Replies
                                                Definitely....
                                AUTOCAD PLANT 3D 2012 is.....
             TOOOOOOOOOOOOOOO SLOW !!!!
Edited by
Discussion_Admin
10 REPLIES 10
Message 2 of 11
ybogdanov
in reply to: batone79
If you don't know use it, it's not a problem. It's like when you drive a BMW, if you don't know change the speed from the first, you can say that the car is tooooooo slow.
Regards
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 3 of 11
batone79
hahaha..nice replay!!..
Yury, do not be angry with what I'm going to say
You know that is really that ACADP3D is Slow, I worked before with Rebis under Acad and was quickly than this and this a big true.
I´m working 3 years with this BMW and I think that I know run, change gear, break and Parking, but maybe I´m not as Halmilton in McLaren.
But remember ACADP3D is not a BMW I think is a Volkswagen Golf.
ACADP3D need more Agility to be productive, I can not wait 15sec. to change a 3D View. 3 sec to erase a pipe.
A can not need 3 mouse clicks to find a tool and so much. that you need.
I think that ACADP3D need get more agility, velocity, stability, make a interface create by users not by psychologists as Ribbon was created and a Big list that you can read in this and other forums.
Thanks Yury and all my respect for you I know that you are a active member and you help to so much people but if we are critical with ACADP3D we will make a better Software.
Message 4 of 11
mike.sims
2013 is faster....
Message 5 of 11
What are your computer specs? 3 secs to erase a pipe isn't normal.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 6 of 11
batone79
My Computer...
Windows 7
LENOVO THINKSTATION D20
Intel Xeon   E5620 @ 2.40GHz  2.40GHz
16GB RAM
NVIDIA Quadro 2000.
Message 7 of 11
jason.drew
Some additional questions:
  1. How complex are you models? (equipment, XREFs, etc.)
  2. How are the models divided up? (piping, steel, equipment, etc.)
  3. How well are the models divided? (by line number, service, etc.)
If you have some screen captures of the models you are using (showing the amount of detail) that would help to troubleshoot as well.
Jason Drew
Designated Support Specialist
Message 8 of 11
I would maybe also check the settings in 3DCONFIG and see if the hardware acceleration is causing an issue?
Tomislav Golubovic
Autodesk, Inc.
Message 9 of 11
Firtst I want to say thanks to Yury, Tomislav and Jason for your interest.
Well I expose all data requiered.
Complex of the Models. Some Pumps or Equipment are Downloaded from Manufacturer, but normally Equipment, Pipes, Valves and so on, are Parametrics Drawings.
Models Set Up. I divided by type and Xref in a Master Drawing to do a final Model.
My ACADP3D 3DCOFIG... degradation Order is All Checked.
Thanks again..!!
Message 10 of 11
Click on Manual Tune, what's it say?
Tomislav Golubovic
Autodesk, Inc.
Message 11 of 11
batone79
My Manual Tuning
In Current Effect Status, only Smooth Display and Texture Compression is OFF.
Thanks.!
”Boost
