Definitely....
AUTOCAD PLANT 3D 2012 is.....
TOOOOOOOOOOOOOOO SLOW !!!!
Edited by
Discussion_Admin
If you don't know use it, it's not a problem. It's like when you drive a BMW, if you don't know change the speed from the first, you can say that the car is tooooooo slow.
Regards
hahaha..nice replay!!..
Yury, do not be angry with what I'm going to say
You know that is really that ACADP3D is Slow, I worked before with Rebis under Acad and was quickly than this and this a big true.
I´m working 3 years with this BMW and I think that I know run, change gear, break and Parking, but maybe I´m not as Halmilton in McLaren.
But remember ACADP3D is not a BMW I think is a Volkswagen Golf.
ACADP3D need more Agility to be productive, I can not wait 15sec. to change a 3D View. 3 sec to erase a pipe.
A can not need 3 mouse clicks to find a tool and so much. that you need.
I think that ACADP3D need get more agility, velocity, stability, make a interface create by users not by psychologists as Ribbon was created and a Big list that you can read in this and other forums.
Thanks Yury and all my respect for you I know that you are a active member and you help to so much people but if we are critical with ACADP3D we will make a better Software.
What are your computer specs? 3 secs to erase a pipe isn't normal.
My Computer...
Windows 7
LENOVO THINKSTATION D20
Intel Xeon E5620 @ 2.40GHz 2.40GHz
16GB RAM
NVIDIA Quadro 2000.
Some additional questions:
If you have some screen captures of the models you are using (showing the amount of detail) that would help to troubleshoot as well.
I would maybe also check the settings in 3DCONFIG and see if the hardware acceleration is causing an issue?
Firtst I want to say thanks to Yury, Tomislav and Jason for your interest.
Well I expose all data requiered.
Complex of the Models. Some Pumps or Equipment are Downloaded from Manufacturer, but normally Equipment, Pipes, Valves and so on, are Parametrics Drawings.
Models Set Up. I divided by type and Xref in a Master Drawing to do a final Model.
My ACADP3D 3DCOFIG... degradation Order is All Checked.
Thanks again..!!
