AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
AutoFlange with DIN flange and ASME pipe
2 REPLIES 2
ybogdanov
969 Views, 2 Replies
 when I use mixed spec, where pipes are ASME and flanges DIN. I allow all mixed connections. And when I want to connect BV end of DIN flange with PL end of ASME pipe it's connected ok. But the problem is in the AutoFlange connection. Because in this case it's not connected.
Any solution?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
2 REPLIES 2
ybogdanov
in reply to: ybogdanov
The solution is to modificate Connection xml file on the project.
Yury Bogdanov
Barcelona (Spain)
andreluisoazen
 Could you post a tutorial how to do this?
I have the same problem, where a i work the internal Norm use Pipe ASME/ANSI and Flange DIN
Thanks.
”Boost
