AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
AutoCad Plant 3D 2014
5 REPLIES 5
richard.imrie
1097 Views, 5 Replies
Anyone else having problems creating iso's where blind flanges are part of the line?
5 REPLIES 5
with failure code 'FAILURE - eNullExtents'
No, I have no problem with that.
Attila Vallyon
Indesh
in reply to: richard.imrie
Hi there, Can you send a snap shot of your problem??
Hi there,
I should have updatyed this call. It was solved by redefining the block from the isosymbols.dwg
Although i am still not sure what the 'einvalidextents' actually means. What was strange was that once i redefined the block 'flange' the iso still didnt work, However when i logged onto a different computer and tried to iso from the same project file it worked fine. Then a week later the same project started acting up again and i haven't been able to iso anything other than straight length of pipe.
At the moment i am doing a complete uniinstall and reinstall.
dpreezm
Hi there,
I Also got that message and "eInvalidExtents" and found that also if you have unsupported elements such as text in your Isosymbol block you will get that message, at least thats what I figured out.
Good luck
-=StevieWonder=-
"Trust me, I'm a draftsman"
”Boost
