AutoCAD Plant 3D General
dpenney
Message 1 of 4 (395 Views)
AutoCAD Plant 3D Drawing Templates
395 Views, 3 Replies
10-09-2013 10:39 PM
We are currently installing and eventually setting up AutoCAD Plant 3D 2014.
We have used this program a number of years since its inception.
However, we no longer have P3D operators/administrators available at this time in the company, but we would like to establish the basic templates right now for future work.
We have updated all of our Autodesk Suites and Templates accordingly...and use our Border sheets in Paper Space along with dimensions and text, etc. at 1: 1. Model space is only used for the models/geometry - also at 1:1.
All of our drawing files will also be Vault Professional 2014 based from now on.
What we would like - with possibly only a few tweaks - is to use the exact same drawing templates with Paper Space borders and title blocks in Plant 3D for our overall Plant GA's and subsequent Piping ISO's.
Is this possible without any issues.....or do we have to have totally separate Templates in Model Space just for Plant 3D?
The only reason i am pushing this now, before we get P3D operators again, it to have the templates made ready with all other project templates used by the other suites.
Any helps or suggestions would be appreciated.
Cheers
David Penney
Product Support
VinodBalasubramanian
Message 2 of 4 (349 Views)
Re: AutoCAD Plant 3D Drawing Templates
10-13-2013 07:05 PM in reply to: dpenney
As long as your projects are created properly and vaulted as per the help document below, you should be able to use your customized templates for your ISO drawings across all users.
http://docs.autodesk.com/PLNT3D/2013/ENU/index.html?url=filesPSU/GUID-735CFAFF-0BBC-497E-84A7-633C88...
If this isn't that you are looking for, can you provide more specifics on your requirements.
Vinod Balasubramanian
dpenney
Message 3 of 4 (345 Views)
10-13-2013 07:23 PM in reply to: VinodBalasubramanian
Hi and thank you for your reply.
I guess what I am trying to ask is this and I don't know how I can make it any clearer really.
Can we just have our normal Template Borders and subsequent text in Paper Space at 1:1 in Plant 3D (all geometry/models, etc are in Model Space) for P&IDs, orthographics and piping isomentrics?
Or do we have to put these drawing borders, text and dimensions in model space also when using Plant 3D?
Our normal AutoCAD Mechanical drawing sheet borders, dimensions and text (at 1:1) are in Paper Space - with geometry only (at 1:1) on Model Space.
Cheers.
*Expert Elite*
dave.wolfe
Message 4 of 4 (313 Views)
10-14-2013 06:22 PM in reply to: dpenney
I haven't tried putting the borders in model space in the isometrics, but these require custom title block setup anyways. For everything else, the border can go in paper space.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
