AutoCAD Plant 3D General
Valued Mentor
dennis
Message 1 of 7 (1,351 Views)
Accepted Solution
AutoCAD Plant 3D Content Packs - 2014
1351 Views, 6 Replies
05-22-2013 12:01 PM
There are two new packs, released on May 16 and May 14.  One is really new, the IPEX, and there is not an equivalent in the 2014 Content folder.  Contrast that to the second one, ASME Catalogs with weights, there are equivalents of name in the 2014 Content folder.  But these pcat files are different in size, which i would expect if they are to replace the existing 2014, they would both be larger.  So are the new ones, ASME Pipes and Fittings Catalog and the ASME Valves Catalog, replacements of the existing or should they both be kept, the 2014 installed and the new download?  The new ASME Pipes and Fittings Catalog is 19723kb while the 2014 installed is 19,737kb.  The new ASME Valves Catalog is 8911kb while the 2014 installed is 8,837kb.  Odd that one download is larger while the other is smaller.
Employee
rajsekarpillai
Message 2 of 7 (1,303 Views)
Re: AutoCAD Plant 3D Content Packs - 2014
05-23-2013 09:32 AM in reply to: dennis
HI,
1. IPEX catalog is to address the market demand of Sch 40 & 80 plastic pipes, fittings, Valve catalog.
2. ASME Catalogs with weights. This is update of existing ASME with weight details. You can replace the 2014 ASME with this one.
** Please read the specific readme for the content pack before replacing the existing one. Always take the backup of your catalog and spec before replacing.
Catalog size doesn't say much and please look at the number of part families. It should be the same as 2014 cpack.
Kind Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Autodesk, Inc.
Ahmed1081975
Message 3 of 7 (1,295 Views)
05-23-2013 10:05 AM in reply to: dennis
So if I have many of custom components what shall I do??
Ahmed Helal
Valued Mentor
JohnHolder
Message 4 of 7 (1,287 Views)
05-23-2013 10:33 AM in reply to: rajsekarpillai
It's great that there is a small selection of pvc pipe, but for me it is still going to be unused since the catalog is still missing too much.  no fittings over 12" means I will continue to use the catalog that I had to model up myself.
It is a good start, it would have been nice if it was a complete catalog.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Employee
rajsekarpillai
Message 5 of 7 (1,285 Views)
05-23-2013 10:35 AM in reply to: Ahmed1081975
You can copy the part family through Catalog editor.
1. Open Specs and catalog editor => open both the catalog.  => switch to Catalog editor => Select your custom part family => right click => copy
2. Switch to your new catalog => right click on the catalog Browser=> select any one of the part family => paste
Please refer the attached snapshots.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Autodesk, Inc.
Employee
rajsekarpillai
Message 6 of 7 (1,281 Views)
05-23-2013 10:40 AM in reply to: JohnHolder
Please post your content pack request on this form and give the link of manufacturer.
http://autocad.autodesk.com/?nd=form__105
Or  send an email to plant.content@autodesk.com with your PDF manufacturer catalog.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Autodesk, Inc.
Valued Mentor
JohnHolder
Message 7 of 7 (1,275 Views)
05-23-2013 10:43 AM in reply to: rajsekarpillai
I contacted spears directly, put in content requests.. spears told me there is one already ( woefuly inadaquate ) and it took 2 years+?! to get this one.  I am content to use mine for now.
It is nice they have something.. unfortunatly what I do is a little off the beaten track so I do not expect a full catalog to be put out that I can use, basically out of the box.
Master Yoda.
You are not logged in.
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
