AutoCAD Plant 3D General
Valued Mentor
ybogdanov
Message 11 of 26 (810 Views)
Re: AutoCAD Plant 3D Catalog Builder (Beta) is available now
10-20-2011 11:43 PM in reply to: EileenForan
Win 7 prof 64bit, work correctly
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Valued Contributor
Message 12 of 26 (805 Views)
10-21-2011 11:59 AM in reply to: rlpacle
To install it, you need to unRar into your AP3D intalled folder, (Autocad Plant 3D english) and run it...
and Voila!..it´s works..!
Valued Mentor
ybogdanov
Message 13 of 26 (773 Views)
10-27-2011 06:27 AM in reply to: EileenForan
 In the case when I go to set the dimensions in the excel, in the column of OD (out diameter) I write the values in mm, for example:
 88,9 - for pipe DN80
114,3 - for pipe DN100
When I export this excel sheet from Catalog Builder to one exist catalog the program don't recognize "coma", the OD result diameters are:
889
1143
Yury Bogdanov
Barcelona (Spain)
Employee
rajsekarpillai
Message 14 of 26 (754 Views)
11-01-2011 01:16 AM in reply to: ybogdanov
Currently, The Beta is only support period (".")delimiter.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Valued Mentor
ybogdanov
Message 15 of 26 (748 Views)
11-01-2011 09:17 AM in reply to: rajsekarpillai
Thanks & Regards,
I was prove with "." delimiter and it don't work too.
Yury Bogdanov
Barcelona (Spain)
Employee
rajsekarpillai
Message 16 of 26 (735 Views)
11-02-2011 12:04 AM in reply to: ybogdanov
I think this could be the computer delimiter issue.
Go to Control panel -> Region and Language -> click the Formats tab -> click the additional settings button -> change the “list separator” to “.”Instead of comma.
If this doesn’t work, please attach your excel file and I will try at my end.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Valued Mentor
ybogdanov
Message 17 of 26 (731 Views)
11-02-2011 01:28 AM in reply to: ybogdanov
This is the excel
Yury Bogdanov
Barcelona (Spain)
Active Contributor
Message 18 of 26 (726 Views)
11-02-2011 08:18 AM in reply to: EileenForan
When I try to start AutoCADPlant3DCatalogBuilder.exe Windows 7 64 German tells me that the program doesn't work anymore. The HowTo actually doesn't mention this AutoCADPlant3DCatalogBuilder.exe. So I'm wondering if it's needed at all.
Thanks for hints
Carsten
Valued Mentor
ybogdanov
Message 19 of 26 (665 Views)
11-27-2011 11:44 AM in reply to: cbeinecke
When the template are created with all objects of new catalog, and we create the excel, after one hour of defined the geometry of objects in excel I find that my nipple have all connection points together...( is imposible to define the each connection point separatly, one PL another FL for example). Which is the solution? Change the config in Catalog Builder and turn to create excel (purgeing my one hour of work)? Is posible to change only this object in CatalogBuilder and others sheets of excel don't touch, because have all geometry of objects defined.
Yury Bogdanov
Barcelona (Spain)
GeorgeKamieniecki
Message 20 of 26 (539 Views)
02-07-2012 05:45 AM in reply to: EileenForan
Hello Eileen,
 I dowloaded Catalog Builder and followed all the steps in the accompanying docx file.
I was unable to run the testacpscript lisp program as mentioned in point 4 of the docx. This file does not appear to be available anywhere I have searched.
Point 5 e in the docx reads:
 "Save the image to custom script folder. When user request the custom script images by image API, the image API will scan the custom script folder to fetch the images which meet requirement."
Please elaborate on "request the custom script images by image API".
Where does in fact TestScript component get accessed from? Plant3D? Spec Editor?
I feel I am missing some background on how and where I can put Catalog Builder to use.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
