Log into the Subscription Center to download the extension:
AutodeskĀ® AutoCADĀ® Plant 3D 2014 Extension 2 is an extension to AutoCAD Plant 3D 2014 that adds the following functionality:
In addition, there have been numerous improvements to isometric generation:
We have also addressed minor bug fixes not related to isometrics.
I have a case opened at Autodesk Support since mid-december (!) for that kind of matter : it seems that extension 2 isn't really installed but it says it's installed (when I launch again extension 2 installer). Really strange... but still nothing interesting from Autodesk Support.
Good luck,
Alexandre Devos
Peter,
I don't know if Extension 2 will install when SP1 is installed. I suspect it won't. If you are on subscription, you will get the benefits of SP1 by installing Extension 2. If you are not on subscription, install SP1.
