AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
AutoCAD Plant 3D 2013 Multiple Viewports
2 REPLIES 2
AET_AJa
568 Views, 2 Replies
Autocad hangs when you try to grip edit traditional non-ortho viewports.
This post is very similar to another post dated 2012-05-28.
We encounter excacly the same thing. But unfortunately we can't use the solution from the other message: We have tried to change to Autodesk's recommended driver version (NVIDIA Quadro FX 30800. Version 8.17.12.7642) but no luck.
We are runnig on 64 bit Windows 7 with Plant service packs installed.
If we do the same thing (on the same drawing) in standard AutoCAD we don't have the problem.
If we do it in Plant 3D on a drawing with only 1 viewport, we don't have the problem. Is this a bug?
2 REPLIES 2
ted.moberg
in reply to: AET_AJa
We are seeing the same issue here1  This is a deal killer for us.  This issue has to be fixed or we will get too many people in th office that want to move to a different application.
ted.moberg
The issue will not occure untill after I close the drawing, close Plant (properly) and upon opening the drawing and grip editing the viewport....HANG....
”Boost
