Hi guys,
Is there anyone that has come across this or found a solution. Our company has recently moved onto P&ID and I have been given the task of creating the project template file.
My question is 'How do you add flip and rotations to P&ID symbol?' an eg is the end cap in AutoCAD P&ID, once inserted if you click the cap it gives you the option to flip it. I can't seem to get this to work and was wondering what is the process in doing so.
Craig.
Solved by Attila.Vallyon. Go to Solution.
Go to project settings:
PID DWG settings\PID class definition\
than select your item (engineering or non engineering item
And in the property name add the following:
HasFlowDirection |
Type: Boolean
And set the default value to true
Now you can flip the direction of the symbol with selecting it and click on the small arrow.
Thanks mate...perfect, just what I was looking for. It is unfortunate that you don't get an option to rotate the symbol.
Yes. That is the only thing what works.
The P&ID symbols are not compatible with the dynamic blocks:
