Is there a way to create a tag setup to autogenerate valve number starting with the sheet number? Say on P&ID sheet # 01, I want the valve numbers to start with the page number (01) and then the valves in sequence. So the first valve (say it's a ball valve) would be B-0101. The second one would be B-0102 and so on.
Thank you.
You should be able to accomplish this through the project setup. I would first recommend referring to the AutoCAD P&ID document called, AutoCAD P&ID Customization: Everything from Tags and Annotations to Symbols. This will help you with your questions as well as any additional future customization.
I will also, be posting a link to an Autodesk Screencast video showing how to setup the valve tagging you are wanting to setup. I will post that shortly to your forum post as well.
Quentin Contreras
Technical Support Specialist
Here is the link to the video that I mentioned in my other post.
https://screencast.autodesk.com/main/details/6fc59dc5-a62a-4184-b0ed-b23886b54f3a
However, one step was overlooked. Make sure the vavle tags VALVECODE define expression is changed to No expression (free style value). At the end of the video, a question mark appears when I try to edit the valve. This is cause by not setting it to No expression (free style value).
Quentin Contreras
