Hi there,
In Isometric BOQ, we are getting Flange, Gasket, BoltSet as an individual piipng component. But,We want components assembly as item in BOQ. e.g. in lieu of flanges, gaskets, nuts, bolts etc we need Flange Assembly as one item in BOQ. Can you provide me solution for this?
Ram
I dont know if it is ideal for you but, one solution is, you must create a custom component that you will tag or put a description you want. (Eg. Flange Assembly, 300 LB, RF, ASME B16.5). You can connect two flanges, then explode it then convert to block then to a new plant 3d component that you will import to your catalog. Much of an admin work, but if you really want that description in BOM, you can use this method. Thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
