Hi, First time user here (Also sorry if this is the wrong place to post this, I'm running a Student Version of AutoCAD Plant 3D and am unsure if there's a separate forum for support) As stated above, I am running AutoCAD Plant 3D 2014 student version on my home PC with the education 3 year license and am using this program to create a P&ID diagram for a current project. After creating a new project through the project manager, I attempted to create a P&ID drawing from the project manager tab. After entering a new file name, I clicked OK and I received an error; "Unhandled exception has occurred in a component in your application. If you click Continue, the Application will ignore this error and attempt to continue. Filer error Application does not support just-in-time (JIT) debugging. See the end of this message for details." Now I have searched through the forums for similar error messages and seems that some people have it as a hardware issue or there's a problem with Microsoft .NET framework. I have repaired .NET framework and my graphics adapter driver is updated to the latest version yet I am still getting this error. Since AutoCAD is mainly for the workforce, does it matter that I am using a consumer grade graphics card? Currently using Nvidia GTX 670 if its necessary. What can I do to fix this problem? Is there even a solution? If needed I can upload the error message that I got with all the details.
