AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Another error AEC Dimension
5 REPLIES 5
1590 Views, 5 Replies
Hi everybody.
I just got another error from this software... AEC dimension: opening/door/window associativity initiation failed. Has anyone else got this one? Thanks in advance!
5 REPLIES 5
TomislavGolubovic
That looks like a Revit or MEP error?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
in reply to: TomislavGolubovic
Dear Tomislav
Well, the program I'm running is Plant 3D as shown in the screeenshot. Regards
TomislavGolubovic
Yes, true, but where did the original DWT file come from? Is there definitely no Revit/MEP or something else calling up doors/windows somewhere in the background.
Does the same happen on a blank project with no changes to templates or files?
Tomislav Golubovic
Autodesk, Inc.
That's the only program that was currently in use. It doesn't show on a blank project, but it has show frequently on the one i'm currently working on. Any ideas?
TomislavGolubovic
ok, so it doesn't do it on a blank project, but it does it on this one? To me, that means that the .dwt file you are using for the P&ID has something wrong with it. Can you clean it out, test the PID with other .dwt files.
If you find its not the .dwt, was the P&ID opened in another piece of software and corrupted somehow?
Tomislav Golubovic
Autodesk, Inc.
”Boost
