Hi everybody.
I just got another error from this software... AEC dimension: opening/door/window associativity initiation failed. Has anyone else got this one? Thanks in advance!
That looks like a Revit or MEP error?
Dear Tomislav
Well, the program I'm running is Plant 3D as shown in the screeenshot. Regards
Yes, true, but where did the original DWT file come from? Is there definitely no Revit/MEP or something else calling up doors/windows somewhere in the background.
Does the same happen on a blank project with no changes to templates or files?
That's the only program that was currently in use. It doesn't show on a blank project, but it has show frequently on the one i'm currently working on. Any ideas?
ok, so it doesn't do it on a blank project, but it does it on this one? To me, that means that the .dwt file you are using for the P&ID has something wrong with it. Can you clean it out, test the PID with other .dwt files.
If you find its not the .dwt, was the P&ID opened in another piece of software and corrupted somehow?
