AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Adding a spec
9 REPLIES 9
Message 1 of 10
JohnHolder
1265 Views, 9 Replies
Adding a spec
I am having an issue adding a new pip spec.
I have fixed the sch 40 spec adding in all the missing pipe fittings
Now I am trying to add PVC-U the metric equivalent,
I have noting to start with so I added all the pipe sizes and when I tested it the pipe would not route at all
So I checked how they looked in the spec editor and the sch 40 had no graphic while my new PVC-U did.
Anyone point out how to add a new pipe style. I have all the fittings modeled so I can add those easily enough
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
9 REPLIES 9
Message 2 of 10
jason.drew
in reply to: JohnHolder
Hi John,
Are you modifying the existing Sch 40 PVC spec that ships with Plant 3D or is this a new custom catalog?
Thank you,
Jason Drew
Designated Support Specialist
Message 3 of 10
JohnHolder
in reply to: jason.drew
It will most likely have to be a new catalog I guess.   It is not sch 40.  it's PVC-U  All countries use it except Canada and the US.  Honestly I am suprized there is no mention of it in the plant 3d.
Master Yoda.
Message 4 of 10
Rich.O.3d
Heres a cut/pste from another post:
Might help with the new metric pipe creation...
"In the catalog editor, pick...Use Plant 3d Parametric Graphics...Fittings....Sleeve...BV
now scroll all the way to right in geometry window........Pipe/Pipe(pe)
found it by accident....nice place for the autodesk team to hide them!"
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Message 5 of 10
JohnHolder
in reply to: Rich.O.3d
Ah yeah I'll that!
Master Yoda.
Message 6 of 10
jason.drew
Unplasticised Polyvinyl Chloride, Correct?  Smiley Happy
Are you needing to setup the PVC-U pipe itself?
You could set this up as "Pipe" in the catalog using a parametric shape with the "PPL" (plastic plain-end) end type similar to what is used with the AME Plastic Pipes catalog.
Jason Drew
Message 7 of 10
JohnHolder
ok that is what I am looking for - Unplasticized Polyvinyl Chloride.
Is there a spec for that in plant 3d?
I belive it may ISO 1452-2009 or similar.
Unfortunatly I am having a very hard time finding good information on it.
Master Yoda.
Message 8 of 10
jason.drew
Currently there is not a content pack for the U-PVC spec. You would need to modify an existing catalog/spec or create a new one with the correct dimensions, part descriptions, etc. The AME plastic parts may be the closest match to start from. The PVC Sch 40 and Sch 80 specs were built from that catalog.
The content team is looking for new content pack reqeusts. I would recommend sending in a request using this link below:
http://autocad.autodesk.com/?nd=form__105
Thank you,
Jason Drew
Message 9 of 10
JohnHolder
Yeah I sent them a fittings catalog already.
and also requested a complete sch 40 catalog from spears via the request page.
Master Yoda.
Message 10 of 10
jason.drew
Hi John,
I just wanted to let you know that the George Fisher PVC-C, PVC-U & ABS Content Pack has recently been released on the AutoCAD Plant Exchange:
Thank you,
Jason Drew
”Boost
