Does anyone know how (using AutoCAD Plant 3D 2013) to add a nozzle to a pump discharge nozzle so that a pressure instrument can be added? I need to add a threaded connection (nozzle) to a pump discharge nozzle so that I may attach a pressure gage to monitor pump discharge pressure.
Pumps manufactured to the ANSI standard have the discharge nozzle drilled & tapped to add pressure monitoring instrumentation.
Sorry, I'm kind new in the discussion forum =P. So, I don't understad wath you want to do.
Can you send me a picture? What kind of pump you need?
The solution for this kind of problem when the list of equipment provided for Plant 3D is not enough is this:
I design the equipment in AutoCAD or Inventor 3D block and then I convert the block to be part of Plant 3D. Before that I convert all the nozzle in point connection with the properties I'll need, for example (BV, FL, etc.)
In the image below I draw a box with a imaginary nozzle and I converted in a equipment. You can add all the nozzle you want
If you need more information of the procedure let me know
Regards
