We need a "Add property option" in Plant toolbar for making the solid objects to be intelligent and that can be used in annotion in ortho view also will help to find the description in Navisworks.
1. Presently in Plantspace, there is no option to create RCC (civil) and Electrical (cable trays). These can be done only using raw autocad or using other Autocad softwares, however with these there is no option is possible to annote in ortho view.
2. Its very difficult for Autodesk now to make all the shape intelligent in plant space at this moment.
3. Without making the solid objects (RCC elements, Cable tray elments)intelligent, it would be highly difficult for us and also for any companies to use the software for higher capacity projects.
4. To make the objects intelligent and to be annoted in Ortho view, suggesting the following:
a) There should be tool available in toolbar of plant space "Add property". see attached image-1
b) When mouse click the "Add property", it will ask which object to be selected, when a object is selected, a property window will appear and a value can be added against new propery. see attached image-2
c) In ortho view, if any solid object is selected and press mouse right click, ortho annote-new propery will show. see image-3
4) with new property under ortho annote, the column or anything what had mentioned against new property can be annoted. see image-4
Request from users to share if the above is acceptable, so that Autodesk will understand and the same we can get it
