Is possible to add new properties in SQL server express to Plant3D? I prove that the reverse flow work: if I add the propertie in Plant3D, in the SQL server is appeared. But when I create new in SQL in Plant3D Data Manager there isn't...
I use Plant3D 2012 and SQL server express 2008.
Regards
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
