AutoCAD Plant 3D General
Message 1 of 2 (134 Views)
Accessing weight and description properties of P3D entities using the API
134 Views, 1 Replies
09-04-2012 03:13 AM
I'm trying to access the weight and description of entities in a plant 3d model (pipes, connectors etc) using the api, but after scouring through the sdk docs and google, i still have noe clues left on where to find them.
My code so far is this:
Using trans As Transaction = _sourceDB.TransactionManager.StartTransaction()
    Dim blockTable As BlockTable
    blockTable = trans.GetObject(_sourceDB.BlockTableId, OpenMode.ForWrite)
    Dim record As BlockTableRecord = trans.GetObject(blockTable(BlockTableRecord.ModelSpace), OpenMode.ForRead)
    For Each blockId As ObjectId In record
         Dim ent As Entity = trans.GetObject(blockId, OpenMode.ForRead)
         If (TypeOf ent Is Pipe) Then
             Dim pipe As Pipe = ent
             'how do i acccess plant 3d properties here????
    Next
End Using
Any ideas???
Henrik
*Expert Elite*
dave.wolfe
Message 2 of 2 (124 Views)
Re: Accessing weight and description properties of P3D entities using the API
09-04-2012 08:10 AM in reply to: henrik.rudstrom
There is an example of getting an objects properties using the datalinks manager in the Plant SDK.  The weight will be one of the properties.
It won't do you any good, unless you already have filled in the weights in your catalogs.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
