I gathered a few question, and hope You can help me to find the solution:
1. How can I make flanged pipe element, that in 3D looks like a flanged pipe?
There is flanged pipe Plant3D custom component, but when I put it down,
the model looks like as a normal pipe without flange...(okay, the endtype is
FL, and the next element is always a flange but only from the opposite side,
and it looks bad.)
2. I made a new symbol for a flange, and I want to make, that in a flanged connection
the first flange looks with a normal position symbol in the iso, and the second
looks mirrored(or 180deg rotated)?
3. How can I make the ISO BOM, to write my reducers both dimension, with real
Outside diameters, not with NDs?
4. How can I define the ISO line tag, to look like this:
"Size - Service - Area - LineNo - Spec - Insulation"
(default: "TagFormat(default:LineNumber) - Size - Spec")
Should I config the xml, or is it able inside the software?
5. In the catalogue, by the bolts, the Long Description Family(Size), there is no
Batch assigned text with properties. It looks like,that was made manualy, but
that could be hell of a job. Especially I need this, to write out my bolt sizes.
I think the "@@@" in the annotation should write it out, but how can I generate
that kind of text, or annotation? Should I write it in manually, maybe in excel?
Thank You people,
Laszlo
