AutoCAD Plant 3D General DIscussion
Ahmed1081975
Message 11 of 17 (128 Views)
Re: 90 Degree Elbow Incorrect Showing in the ISO drawing
05-07-2013 11:43 AM in reply to: Arun_Kumar_K
Thanks For Your Interesting, Just i can't understand what do you mean weld gap?
Ahmed Helal
Product Support
Dan.Scales
Message 12 of 17 (123 Views)
05-08-2013 03:00 AM in reply to: Ahmed1081975
Hi Ahmed,
Is you pipe model drawn at high coordinates?
If so, try moving it closer to 0,0 and recreate the Isometric.
Dan
Dan Scales
Distinguished Contributor
Arun_Kumar_K
Message 13 of 17 (112 Views)
05-08-2013 05:22 AM in reply to: Ahmed1081975
Please see the attached pic, remove the check box against weld gap, redraw and you will get the output.
Ahmed1081975
Message 14 of 17 (103 Views)
05-08-2013 10:02 AM in reply to: Dan.Scales
Hi Dan Welcome Back Long time,
I will assuming it will work after moving the plant, in this case the coordinate it will show in the generated isometric wrong so is that real solution
Ahmed Helal
Ahmed1081975
Message 15 of 17 (97 Views)
05-08-2013 09:08 PM in reply to: Arun_Kumar_K
Thanks very much Kumar,
I appreciated your assistant to try solve my issue,  your concern to uncheck for the pipe gap I have already by default as Uncheck still I have the proplem and up till now Autodesk they can’t solve ?
Ahmed Helal
Product Support
Dan.Scales
Message 16 of 17 (91 Views)
05-09-2013 02:43 AM in reply to: Ahmed1081975
Hi Ahmed,
If this is caused by high coordinates the only workaround is moving to lower coords.
This is something that has been logged with our developers.
Dan
Dan Scales
Arun_Kumar_K
Message 17 of 17 (85 Views)
05-09-2013 07:14 AM in reply to: Ahmed1081975
Can u copy a problematic line and save in a new project file and upload here, I ll examine and let u know. If u can't upload here, please send to my email I'd arunkumar.k@thermaxindia.com
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
