Hi Autodesk Support,
I have an issue for generating Isometric Drawings,
I have line with 90 degree elbow showing wrong direction
For more clarification Refer the attached file.
Ahmed Helal
This not my issue my issue the Elbow in the Isometric Shown Wrong in the Drawing
Ahmed Helal
Thanks for Your Reply, my default Setting is saving drawing in 2010
Ahmed Helal
Check your Isometric Symbol (Acad Block) From your Project Setup.
Should be something like this.
Thanks Very Much For your Reply, the point is coming some places with correct direction and another places incorrect
This not solve the problem the problem in the Isometric.XML fine but where I can't find
Ahmed Helal
Thanks For Your Interesting, Just i can't understand what do you mean weld gap?
Ahmed Helal
Hi Ahmed,
Is you pipe model drawn at high coordinates?
If so, try moving it closer to 0,0 and recreate the Isometric.
Dan
Please see the attached pic, remove the check box against weld gap, redraw and you will get the output.
Hi Dan Welcome Back Long time,
I will assuming it will work after moving the plant, in this case the coordinate it will show in the generated isometric wrong so is that real solution
Ahmed Helal
Thanks very much Kumar,
I appreciated your assistant to try solve my issue, your concern to uncheck for the pipe gap I have already by default as Uncheck still I have the proplem and up till now Autodesk they can’t solve ?
Ahmed Helal
Hi Ahmed,
If this is caused by high coordinates the only workaround is moving to lower coords.
This is something that has been logged with our developers.
Dan
Hi @Ahmed1081975 , @Dan.Scales
Was this ever resolved? I have the same issue, but only seems to occur with certain users.
The co-ordinates of the pipe don't make any difference, even with one end of the line on 0,0,0 some of our users have this issue.
Graham
Hi @nikele ,
The pipe spec I was having this problem with was one I had created with my own endcodes, but I hadn't updated the PLANTENDCODES of the other users to match what I had set up on my own machine - once I did this it solved the problem. Our shared content folder is on a network drive, but I had forgotten that PLANTENDCODES (I had just started using Plant 3D) isn't stored in the shared content folder. Hope this helps.
Graham
