Hello
I used PLANTPARTCONVERT to creat new fitting 3R 45 ELBOW and added it to our spec. When i have generated the ISOMETRIC angle shown is 43. See attached pics. Is there anything that I am doing wrong?
Using Plant3d 2012
Thanks for any help or pointers
Samson Thomas
Do you have cutback elbows enabled?
If you select the elbow and open the Properties Palette you can check under "Part Geometry" to see if a cutback angle has been applied to the elbow.
Dan
Hello Dan,
Thanks for the reply. I tried with cutback elbows disabled. I still did not work properly. I created a brand new project and this new spec worked just fine.
Thanks for your reply.
Samson
