Anyone having trouble after creating an Isometric DWG that the "Flange" symbol is shown what looks like a duplicate symbol. Therefore, it looks like 3 lines, instead of a standard 2 line flange symbol. Any help to resolve this would be helpful. Thanks.
Paul
Hello Paul,
Would it be possible for you to include a screen capture of the model as well where the valve and flange are located.
Also, are you using a custom Iso style? If so, try using an out of the box Iso style and see if you get the same results.
Quentin Contreras
Technical Support Specialist
I've attached a screen shot of the model. They are connected fine. I've used the CS150 spec out of the box... Note: WN Flanges look fine in Isometric.
SO and SW Flanges are the issue.
I looked at the blocks in my Isometric dwg; Flange and Flange-2 and they are show 3 lines. I've attached that screen shot as well.. Something is going on that needs attention... Thanks for any help.
Paul
I had the same issue. I created a new block in IsoSymbolStyles.dwg and it works fine now.
Hmm. This works for me out of the box. Any more details?
I'm going to create a new symbol in the IsoSymbolStyles.dwg and see if that fixes it. I'll let you know.
Paul
Modified the Flange block in the IsoSymbolStyles.dwg and seems to work now. There was a wipeout block next to the linework in that Flange block. Why was that there, I'm puzzled. Thanks for all the help.
Paul
