I have recently migrated my P&ID project from Plant 3D 2012 to Plant 3D 2014. Migration was a success, but when i open a P&ID drawing and try to connect an Off Page Connector to another drawing the program locks up permanently. I have to end the process to get out. I have tried connecting existing lines and connectors, connecting existing lines with new connectors, and even a fresh line with a fresh connector and get the same result, which is a frozen program. Has anyone else experienced this problem or know of any fixes?
When you mean frozen, does it continue to work if you press the escape key? The only reason I ask is that the dialog box might be off the screen.
