AutoCAD Plant 3D Forum
2012 Isometric
4 REPLIES 4
DJPiper
1041 Views, 4 Replies
2012 Isometric
There is this Line Number Appears beside the extracted isometric, how can we change the format? or maybe if i want to turn it off, where's the control for it?
Another thing i've been playing with the continuation text hoping to get a a full drawing number which consist of a combination of properties + user defined text. for now Plant 3D defaults is only giving Line number Tag. so far, no success. Anyone who done this?
Thanks!
4 REPLIES 4
in reply to: DJPiper
I figured how to turn it off. (there may be an easier way.
If  you go to your iproject folder, open up isometric, open up the desired ISO style, open ISOconfig, find the following statement and delete (or modify)
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
DJPiper
yes, your right man. thats where the control is. opening it on xml editor and by deleting the word Line Number or changing the line format from 0 to 1 will turn off that annotation.
i wonder what will be the the set up if i want this annotation to show up in this format, and if this is possible?
         SIZE-SPEC-SERVICE-NUMBER-INSULATION
jason.drew
You might want to check this table for reference. It explains the XML values for the line number scheme:
AutoCAD Plant 3D 2012 - Isometric Configuration
Jason Drew
Designated Support Specialist
Did you have a chance of modifying this annotation on the isometric drawing?
I have a hard time dealing with it.
”Boost
