• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    upgrading from LT2005
    162 Views, 3 Replies
    11-29-2007 02:43 AM
    I am using LT2005 version. Most of my CAD time goes into drawing either P&ID's or floor layouts. I am satisfied with LT2005 for layouts, but would like to do something to ease my P&ID's working.
    Question(s): With P&ID version, what do I loose in layout-drawing respect? Do I gain something? Can I do same drawings with P&ID version as with LT2005? Is the P&ID version still "AutoCAD" regarding simple drawings?
    Ales
    Please use plain text.
    *Jorge Lopez
    Re: upgrading from LT2005
    12-02-2007 08:45 AM in reply to: aknoll
    Hi Ales,
    The AutoCAD Plant P&ID product uses intelligent entities that make creating
    / managing P&IDs much easier. Connections between objects are maintained and
    the entities are linked to a table of non-graphical information. You should
    be able to get all the behaviors you get from simple AutoCAD entities and
    much more. If you do need to produce vanilla AutoCAD DWGs from P&ID DWGs you
    will be able to do so in the next version of P&ID.
    For more information about AutoCAD Plant P&ID, check out:
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=8846460
    You can view a screencast at:
    http://www.autodesk.com/us/autocadpid/interactiveoverview2008/index.html
    Hope this helps.
    Jorge
    "aknoll" wrote in message news:5788027@discussion.autodesk.com...
    Ales
    12-02-2007 10:02 PM in reply to: aknoll
    Hi Jorge,
    Thanks for the answer. I did check the screencasts of P&ID version, but they do not answer my questions. You did for the most part. What does "next version of P&ID " mean? When will it come out? I wanted to download free trial of existing P&ID, but if there is another version coming in couple of weeks (months?), should I wait?
    One more question from my side: can LT 2005 and P&ID coexist on the same computer?
    Ales
    *Jorge Lopez
    12-03-2007 10:49 AM in reply to: aknoll
    I do not have a release date for AutoCAD Plant P&ID 2009. Yes, LT 2005 and
    P&ID can co-exist.
    Below is a response from Peter Quinn in another thread about signing up for
    BETA releases:
    The best thing to do would be to go to Myfeedback and sign up for the Plant
    Customer Council. The customer council is a way for us to get feedback about
    all sorts of issues. We will certainly be publicizing betas and the like to
    those folks. In addition, we will most likely post something in this
    newsgroup and in Ursula's blog
    (http://in-the-pipes.typepad.com/in_the_pipes/) when there is a beta
    available.
    Just to make sure there isn't the wrong impression, we don't have a beta to
    post in the near future as of November 2007.
    The link for Myfeedback is http://myfeedback.autodesk.com. If you're signed
    up already, add Plant Customer Council in the Beta Code field. Otherwise,
    create a new account for yourself and put Plant Customer Council in the Beta
    Code.
    This will be the way that betas are distributed anyway, so you'll need to do
    it when one is available.
    Thanks again,
    Peter Quinn
    "aknoll" wrote in message news:5790500@discussion.autodesk.com...
    Hi Jorge,
    computer?
    Ales
