• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    New Member
    Re: unhandled exception has occured... " at the creation of a new drawing
    01-06-2013 02:30 AM in reply to: alan_mo
    I have exactly the same problem. I'm using Educational Versions of Inventor 2013, Revit 2013 and AutoCAD 2013 for testing, learning and maybe buying later without any problems. Now i would like to get in to AutoCAD Plant 3D / P&ID as well but get unfortuantely the same errors if i try to open a new sketch. Therewith, the Software is not usable.
    I'm testing these Software on a older Laptop running Windows 7 Professional 64 bit, AMD Turion X2, X1250 Graphics, 4 GB RAM where the other Autodesk Software runs very well and smoothly.
    If anyone has a soluton please write me back. To all the others: good luck and maybe use Inventor in stead, it has piping too.
    Bernd
    Please use plain text.
    New Member
    01-29-2013 08:25 PM in reply to: BSTConstruction
    I'm going to bump this topic to see if anything new has come up, because I am having the exact same error are the original post.
    Windows 7 (64 bit)
    Also (when I manage to get a drawing open) and i try to open the project setup page, I get the error that I have attached(Error 2)
    Any help???
    New Member
    02-17-2013 01:01 AM in reply to: Lightnings
    I am too facing the same problem. Details of my software are:
    Autocad P&ID 2012 Student Version (x64)
    Was learning the training manual, I could not create a new drawing file under a folder.
    Project directory
    I was creating a new drawing file in the folder "Water". I have tried other templates also but the error is same...
    Error
    Active Member
    02-23-2013 09:05 AM in reply to: srikanthchilivery
    I take it Autodesk are not really bothering with this problem or taking it seriously and leaving a lot of people using the educational program unable to complete there studies.
    I am trying to complete a course of study using this program on a Windows 7 machine running 64 bit and have posted about having the same issue on this forum and emailed but had no reply. It seems it is an issue for a lot of people.
    It is a pity they are not being customer focused on this subject as I am becoming seriously disillusioned with this piece of software and may give up trying in the near future. At this stage I wouldn't advice anyone to use it.
    Regards
    Ryan
    Distinguished Contributor
    Rave.Tam
    03-20-2013 10:01 AM in reply to: alan_mo
    Open and Save the Projectsymbolstyle and template used for creating new drawing.
    If you want to know the reason behind this error, check my post here.
    http://lazcad.com/2013/03/how-to-make-plant-3d-student-version-works
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
