AutoCAD P&ID
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
unhandled exception has occured... " at the creation of a new drawing !!
- Highlight
- Email to a Friend
Here is the listing
I installed the product without any trouble.
Have you an idea ?
I cannot create a new PID drawing !
Application does not support just-in-time (JIT) debugging. See the end of this message for details.
************** Exception Text ************** System.Runtime.InteropServices.COMException (0x80200033): Filer error at Autodesk.AutoCAD.Interop.AcadDocumentsClass.Add(Ob
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.239 (RTMGDR.030319-2300) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30
************** JIT Debugging ************** Application does not support Windows Forms just-in-time (JIT) debugging. Contact the application author for more information.
Re: unhandled exception has occured... " at the creation of a new drawing
- Highlight
- Email to a Friend
Could you post some additional information? What version did you install? What operating system? 32 or 64 bit? Screenshots always help.
Pat Jenakanandhini
Product Manager
Plant Solutions - AEC
- Highlight
- Email to a Friend
I have the same problem. I installed AutoCAD P and ID 2012 for 32 Version and I am running windows 7 professional.
- Highlight
- Email to a Friend
I tried repair and reinstall functions of 2012, it did not help.
I also tried Uninstall, delete all the files and re-install 2012, it did not help.
Install 2011 for win 32, it did not work either.
- Highlight
- Email to a Friend
This is what I saw when I just ran it for the first time.
And after closing this message, this error showed when I tried to creat a new drawing
- Highlight
- Email to a Friend
In the "New DWG" dialog, there is an option to specify the .dwt file. Can you try replacing the default .dwt file in that dialog with some other .dwt file and see if that works fine? Looks like you are running the educational version of the product and there is a chance that the default PNID .dwt files didn't contain a proper digital signature for the educational version.
Sr. Principal Engineer
Autodesk Plant Solutions
Autodesk, Inc
- Highlight
- Email to a Friend
Having the exact same problem with educational version.
- Version:AutoCAD P and ID 2012 (English) 64-Bit
- Downloaded:2012-01-23 05:31:21
Problem occurs ; A.When trying to edit project properties. and B. When trying to create new drawing.
I've tried changing template without any luck.
Best regards
Mats Innstø
- Highlight
- Email to a Friend
Hello
I want to test the software before buying it. I acnnot teste if for the moment.
What do I do ?
Rgds
- Highlight
- Email to a Friend
This seems to be a problem with the educational version. I've reproduced the problem om multiple machines, both 32 and 64-bits version. The error also occures when trying to enter project properties in the sample project (first time use of application). Its also impossible to use any template.
Please take this seriously, the program is at the time completely unusable, not only for me, but the whole school.
Best regards
Mats Asvald Innstø
- Highlight
- Email to a Friend
The way I solved it for the time being is looking for the map with the templates.
Open it directly and create(save as) a new one.
I also moved it to a different folder which is not burried somewere unknown into 27submaps.
Then when creating a new P&ID select the new created template and it works.
