• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    report creator problem
    289 Views, 1 Replies
    03-07-2013 11:17 PM
    I cant open Plant Projects in Report Creator. Last week it wasn´t any problems. Anyone have a clue?
    Type: System.IO.FileLoadException
    Message: Could not load file or assembly 'PnPDataObjects, Version=1.0.4770.32995, Culture=neutral, PublicKeyToken=null' or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)
    Stack trace:
    at Autodesk.ProcessPower.ReportCreatorUtils.Database.PlantDatabase..ctor(String databaseFileName, ICollection`1 databaseFilesToAttach, StandardType stdType, SignInFunc siFunc, PlantProject plantPrj)
    at Autodesk.ProcessPower.ReportCreatorUtils.Project.PlantProject..ctor(String xmlProjectFile, SignInFunc siFunc)
    at Autodesk.ProcessPower.ReportCreator.Manager.SetCurrentProject(String projectFile)
    at Autodesk.ProcessPower.ReportCreator.MainForm.OnProjectComboBox_SelectionChangeCommitted(Object sender, EventArgs e)
    Inner exception:
    Type: System.Security.Policy.PolicyException
    Message: Required permissions cannot be acquired.
    Stack trace:
    at System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission)
    at System.Security.SecurityManager.ResolveCasPolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission)
    Please use plain text.
    Valued Contributor
    andy.davis
    Re: report creator problem
    03-11-2013 07:07 AM in reply to: hardell
    Have you recently installed the SP1 Data Integrity Hotfix, by any chance?
    I had exactly the same issue with the Report Creator after installing the hotfix last month.  I did report this to Autodesk Support at the time.  Uninstalling the hotfix restored the Report Creator functionality.
    Andy
