• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Distinguished Contributor
    Rave.Tam
    Re: "No Target" in annotations due to Batch Script
    11-07-2012 05:37 PM in reply to: craig.wood
    Can you try to place the plugin in this directory
    %AppData%\Autodesk\ApplicationPlugins
    You shouldn't need to netload the dll yourself. It should be loaded automatically. Try this command
    lazplantbrowser
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    Please use plain text.
    craig.wood
    11-07-2012 05:47 PM in reply to: Rave.Tam
    That did it! Thanks!
    I'll check it out and come back with some praise soon :smileyhappy:
    Craig
    Rave.Tam
    11-07-2012 06:59 PM in reply to: craig.wood
    great! not sure why it doesn't run from the program files folder.
    craig.wood
    11-07-2012 07:02 PM in reply to: Rave.Tam
    Actually, it turns out that it was running from the program files after all. I think I just needed to restart the program before it would take effect. I deleted the plugin from the appdata root folder and the plugin is running just fine from the program files folder.
    Thanks again!
