• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    questions about the PID
    327 Views, 6 Replies
    01-14-2013 11:21 PM
    Hello, good morning I have several questions about the PID.
    1 - to create objects PID have to indicate if pump tank ... but if there's poemos that category and we do not create problems?. If you can do, how we do it?
    2-we can repeat the tag in different PID?. If you can do, how we do it?
    thanks
    Please use plain text.
    Product Support
    Re: questions about the PID
    01-16-2013 02:20 AM in reply to: joaquinr
    I don't think I fully understand the issues that you are describing.
    Could you provide some more details?
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Active Contributor
    georgeendrulat
    01-16-2013 05:25 AM in reply to: joaquinr
    If possible can you post your question in your native language, there might be someone on here who also speaks/reads that language.
    01-16-2013 09:41 AM in reply to: joaquinr
    first, thank you very much for attending my doubts.
    when we make something in a PID object opens a menu to indicate the category where we will put. (see Screenshot)
    but what if the category is not.
    We can create a category?
    if possible. as you would?
    forgiven for translations, do the google translate because my English is very basic
    Thanks to all
    lo primero, muchas gracias por atender a mis  dudas.
    cuando convertimos algo en un PID object se abre un menu para indicar en la categoria donde lo vamos a poner. (see Screenshot)
    pero y si no esta la categoria .
    podemos crear una categoria?
    de ser posible. como se haria?
    perdonar por las traducciones, las hago con el google translate ya que mi ingles es muy basico
    gracias a todos
    Product Support
    01-17-2013 07:19 AM in reply to: joaquinr
    When using "Convert to P&ID Object" the class type will only be listed in the dialog if there is already at least one symbol associated with that particular class.
    So, in the project setup you need to add the required class type and assign it a symbol. After that you can use the "Convert to P&ID Object" without problem.
    Dan
    Dan Scales
    Autodesk, Inc.
    01-17-2013 10:28 PM in reply to: joaquinr
    this to create a new folder or section in PID OBJECT wondering because I get this:
    -in this project make a rotameter which is a rectangle simply convert to PID OBJECT save the drawing, I close it, I open it and I replaced it the rotameter this tool palettes in the PID-PIP
    -in this project do a drain that is a rectangle simply convert to PID OBJECT save the drawing, I close it, I open it and I replaced it drain that is in the tool palettes PID-PIP.
    esto sucede com mas objetos..
    this happens to me on almost every level, there are other planes are maintained OBJECT PID that I created for this project
    THANKS
    esto de crear un nueva carpeta o seccion en  PID OBJECT lo pregunte porque me pasa esto:
    -en este proyecto me piden un rotametro que es un rectangulo simplemente lo convierto a PID OBJECT salvo el dibujo, lo cierro , lo vuelvo a abrir y me lo ha sustituido por el rotametro que esta en el tool palettes  PID-PIP
    -en este proyecto me piden un drenaje que es un rectangulo simplemente lo convierto a PID OBJECT salvo el dibujo, lo cierro , lo vuelvo a abrir y me lo ha sustituido por el drenaje que esta en el tool palettes  PID-PIP
    y asi con otros ojbetos que creo.
    esto me pasa en casi todos los planos, hay otros planos que se mantienen los OBJECT PID que yo he creado para este proyecto
    GRACIAS
    Active Contributor
    georgeendrulat
    01-18-2013 05:47 AM in reply to: joaquinr
    It seems like you have an issue with templating, block location, and project structure.
    1. Only create new blocks within your template project, the one you select, at new project creation, the project.xml.
    2. All blocks for P&ID should be in the projSymbolStyle.dwg file.
    3. Move your tool pallettes files to a central location and rerefrence them so they are consistant across machines and projects.
    4. Maintain consistant project structures and locations to be able to easily maintain them across projects and time.
    5. Many other basic autocad tasks related to all of this, there are many articles about autocad administration out there, sadly I'm not going to write a long explanation of good practices, but they are out there.
    My two cents.
