• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    gschimmi
    no automatic line breaks after substitution of lines
    376 Views, 5 Replies
    09-21-2012 01:51 AM
    Hi
    I have a horizontal and a vertical line. There is a line break if the lines have a different break priority.
    When I substitute the line with the higher priority with a line class having the same or lower priority so there will be no more an automatic line break.
    How can I fix this?
    GS
    Please use plain text.
    Product Support
    gersteb
    Re: no automatic line breaks after substitution of lines
    09-24-2012 07:59 AM in reply to: gschimmi
    Hi Guido,
    It works fine on my site. Here is a link for a video to show you how it works here. If you see something different from your procedure, please, tell me. What happens if you have a new project with a new drawing. Do you see the same issue there? What happens if you add a new drawing to your old project? The same here?
    http://screencast.com/t/m48BvMV4gwSN
    Regards
    Bernd
    Bernd Gerstenberger
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    gschimmi
    09-27-2012 04:13 AM in reply to: gersteb
    Hello Bernd
    it is the same behavior when creating a new drawing in the old project.
    it is the same behavior when creating a new drawing in a new project, created from our master project.
    it is the same behavior when creating a new drawing in a new project.
    Regards
    Guido
    Product Support
    gersteb
    09-28-2012 07:37 AM in reply to: gschimmi
    Hi Guido,
    Do you use gaps or loops for the line crossing style? What is the value of the gap/loop width? What happens if you do a REGENALL?
    Regards
    Bernd
    Bernd Gerstenberger
    Product Support
    Autodesk, Inc.
    Valued Contributor
    gschimmi
    10-01-2012 01:12 AM in reply to: gersteb
    Hi Bernd
    I use gaps with 5 mm width. REGENALL doesn't help.
    (When I move one of the lines the break will be inserted again.)
    G
    Product Support
    gersteb
    10-01-2012 02:15 AM in reply to: gschimmi
    Hi Guido,
    Thanks for the information here. I can now recreate the issue when I use PIP norm, creating two crossing primary line segments and after substituting one of them with 'secondary line segment - existing' the gap is lost. I logged this now to our developemnt department. The workaround here is to substitute it with 'secondary line segment' and afterwards to 'secondary line segment - existing' back again. Then you will see the gap on the right place.
    Best regards
    Bernd
    Bernd Gerstenberger
    Product Support
    Autodesk, Inc.
