• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    gschimmi
    metric and imperial specs
    129 Views, 2 Replies
    02-27-2012 11:05 PM
    Hello
    in my project I want to use parts from a metric pipe spec and flanges from a imperial pipe spec, but that does not work.
    I always get an error message and an open connection (with two drops).
    Which parameters are checked by plant-3D for comparing the connection of two parts?
    Guido
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: metric and imperial specs
    02-28-2012 06:58 PM in reply to: gschimmi
    In the Joint Settings, have you got the option enabled for Imperial-Metric connections?
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Valued Contributor
    gschimmi
    02-28-2012 10:47 PM in reply to: TomislavGolubovic
    Hello
    No, I have not...but now
    Thank you
