• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    is there any way of making hte tag text not scale with the symbol?
    284 Views, 2 Replies
    12-05-2012 03:16 AM
    I have created a tank symbol which can scale on insert, however the tag scales with the symbol.
    Please use plain text.
    Employee
    Re: is there any way of making hte tag text not scale with the symbol?
    12-05-2012 11:16 PM in reply to: phil.cooper
    Does this happen for all Symbols or just the one? The tag is its own block that is inserted at the same time as the symbol. Have you looked into the scale of the Annotation in the Project Setup?
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Jarrod Mudford
    Plant Solutions Consultant
    Global Services
    Autodesk, Inc.
    Valued Contributor
    12-06-2012 12:13 AM in reply to: JarrodMudford
    ive sorted it now, i wasnt adding any annotation i was just using the tag.
    thanks
