• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    New Member
    connection between blocks/symbols and database
    394 Views, 1 Replies
    08-31-2012 10:46 AM
    Hi all, I`m working with PTC Creo Schematics (former Routed System Designer) for our P&ID’s. We're thinking to change the Software for the P&ID. I’m really surprised which improvement Autodesk made here the last years.
    Here my question. Is it possible to insert a block/symbol for example a valve to the pipeline and then choosing the technical specifications from a dropdown list (database). See example selection by size of the valve.
    Size | Supplier | Part number |  etc. |
    I already found out that I can select different sizes from a preconfigured database but I would like to select for example Size DN100 and all the rest should be filled in automatically. Is that possible without additional software programming.
    Thanks a lot.
    Please use plain text.
    Employee
    KenFauver
    Re: connection between blocks/symbols and database
    09-28-2012 09:37 AM in reply to: dalheimer
    Hi Dalheimer,
    Unfortunately valves in AutoCAD P&ID are not piping specification driven. This is what would allow you to populate said data to you valve.
