• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    Tee.Dee
    Where are blocks referenced from?
    327 Views, 2 Replies
    10-28-2012 05:50 PM
    Just wondering where P&ID blocks in a project are referenced from?
    If I edit a blocks linework in the project settings iv found that it only changes the block contained in the projSymbolStyle.dwg.  Thats all good but what if i want to add a new block, where does this block need to be saved?
    I noticed there are drawings stored under C:\Program Files\Autodesk\AutoCAD P&ID 2013 - English\SymbolLibrary that contain all of the blocks, should I be storing my newly created blocks in one of these drawings?
    If so then I would rather have seperate drawings on the server to add my own blocks to but how then does P&ID find this drawing?
    I hope someone can see what Im getting at and help me out.
    Thanks very much
    Please use plain text.
    Active Member
    Re: Where are blocks referenced from?
    10-29-2012 01:56 AM in reply to: Tee.Dee
    Also new blocks must be a part from the projSymbolStyle.dwg, from the active project. When you select a new block from an other drawing, the block will be copied to the projSymbolStyle.dwg and will be a part of your active project
    Hans Knol
    CADTEAM
    hans@cadteam.nl
    www.cadteam.nl
    Valued Contributor
    Tee.Dee
    10-29-2012 03:42 PM in reply to: Tee.Dee
    Thanks Hans,  I think im getting there, im coming from AutoCAD Elec where things work much differently.
