• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    gschimmi
    Accepted Solution
    Update annotations of the same object in different PIDs
    598 Views, 5 Replies
    09-27-2012 11:26 PM
    Hello
    when I have an object on two PIDs (the symbols are connected) and change a property in one drawing, the referenced annotation will be updated in the second drawing only when it is opened at the same time. Is that correct?
    Shouldn't all database references updated when opening a drawing?
    Guido
    Please use plain text.
    Product Support
    gersteb
    Re: Update annotations of the same object in different PIDs
    10-02-2012 07:46 AM in reply to: gschimmi
    Hi Guido,
    This behavior depends on your setting for the system variable SYNCSTYLESMODE. By default it has the value of 42. Change this to 43. This includes synchronization when you are opening P&ID drawings. Look here in the help for a better understanding of the values of the system variable: http://docs.autodesk.com/PNID/2013/DEU/
    Please, let me know if this helps.
    Regards
    Bernd
    Bernd Gerstenberger
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    gschimmi
    10-03-2012 10:43 PM in reply to: gersteb
    Hi Bernd,
    what I understand from the help is that this variable is responsible for the update  of drawings when there are changes in the project configuration.
    Regards Guido
    Product Support
    gersteb
    10-04-2012 04:43 AM in reply to: gschimmi
    Hi Guido,
    Not for the project configuration but for database - and tags will be saved in the database (in this case in the piping.dcf). So do you have tried it? I have created a video here to show you: http://screencast.com/t/IytGEJigNS
    Please, inform me if this is helpful.
    Bernd
    Bernd Gerstenberger
    Product Support
    Autodesk, Inc.
    Valued Contributor
    gschimmi
    10-04-2012 09:52 PM in reply to: gersteb
    Hi Bernd,
    thanks for your answer.
    But if PID makes an update according to syncstylesmode also all blocks/symbols will be updated with the project configuration. And so dynamic blocks that I have changed in the drawing will be reseted.
    I need a way that only values from the database will be updated.
    best regards
    Product Support
    gersteb
    10-09-2012 01:21 AM in reply to: gschimmi
    Hi Guido,
    Yes and no. If you edit the symbol, for example you change the color of the symbol, this will be synchronized here. But if you change a block, this is not effected by SYNCSTYLESMODE because the blocks are saved in a separate DWG. Please, test it. I n your first request you asked 'Shouldn't all database references updated when opening a drawing?' This is what SYNCSTYLESMODE does with the right value. But it is not possible to update only separate values from the database.
    Best regards
    Bernd
    Bernd Gerstenberger
    Product Support
    Autodesk, Inc.
