AutoCAD P&ID
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Unknown Run Time Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi All
I have a problem with the AutoCAD 2012 P&ID software.
Everytime I try to create a new drawing for a new project I get a JIT error coming up with the message at the bottom of the screen as follows:
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Can anyone help me with this problem?
Regards
Ryan
Re: Unknown Run Time Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
To disable Just-In-Time debugging by editing the registry
On the Start menu, search for and run regedit.exe
In the Registry Editor window, locate and delete the follow registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramewor
k\DbgManagedDebugger
If your computer is running a 64-bit operating system, delete the following registry keys also:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\
Windows NT\CurrentVersion\AeDebug\Debugger HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\
.NETFramework\DbgManagedDebugger
Take care not to accidentally delete or change any other registry keys.
Close the Registy Editor window.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the reply.
I am running windows 7 64 bit and found the first file to delete but cannot find the other three files you have listed.
Regards
Ryan
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I also have this problem, it has left me stuck unable to use your product
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Anyone else have a solution to this problem as the above did not work and I still cannot use this program......
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Anyone from Autodesk willing to answer this question and try to help me solve this problem?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
He is telling you to delete registry keys not files. I had a lot of trouble when I first installed it too. I had to remove all my previous .NET installations and re-install the latest one and reinstall P&ID then it all seemed to work OK.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have deleted these files:
But I cannot find the other two files.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
its probably a good thing you can't find them since he is saying you should delete them anyway.
what is the latest version of .NET that you have on your machine I wonder?
I have .NET Framework 4 extended and the.NT framework 4 client pack and it works fine. before I installed AC i had all kinds of other .NET nonsense installed and ACAD had all kind of problems. Thats all I know about this kind of issue.
