• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Active Member
    Unknown Run Time Error
    561 Views, 8 Replies
    01-20-2013 09:01 AM
    Hi All
    I have a problem with the AutoCAD 2012 P&ID software.
    Everytime I try to create a new drawing for a new project I get a JIT error coming up with the message at the bottom of the screen as follows:
    ************** JIT Debugging **************
    Application does not support Windows Forms just-in-time (JIT)
    debugging. Contact the application author for more
    information.
    Can anyone help me with this problem?
    Regards
    Ryan
    Please use plain text.
    Active Contributor
    georgeendrulat
    Re: Unknown Run Time Error
    01-21-2013 05:59 AM in reply to: ryanmcneil01
    To disable Just-In-Time debugging by editing the registry
    1. On the Start menu, search for and run regedit.exe
    2. In the Registry Editor window, locate and delete the follow registry keys:
      • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger
      • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\DbgManagedDebugger
    3. If your computer is running a 64-bit operating system, delete the following registry keys also:
      • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger
      • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework\DbgManagedDebugger
    4. Take care not to accidentally delete or change any other registry keys.
    5. Close the Registy Editor window.
    Active Member
    01-21-2013 12:41 PM in reply to: georgeendrulat
    Thanks for the reply.
    I am running windows 7 64 bit and found the first file to delete but cannot find the other three files you have listed.
    Regards
    Ryan
    New Member
    01-24-2013 11:32 PM in reply to: ryanmcneil01
    I also have this problem, it has left me stuck unable to use your product
    Active Member
    02-16-2013 10:07 AM in reply to: ryanmcneil01
    Anyone else have a solution to this problem as the above did not work and I still cannot use this program......
    Active Member
    02-23-2013 09:07 AM in reply to: ryanmcneil01
    Anyone from Autodesk willing to answer this question and try to help me solve this problem?
    Valued Contributor
    kennethmjones
    02-23-2013 04:56 PM in reply to: ryanmcneil01
    He is telling you to delete registry keys not files. I had a lot of trouble when I first installed it too. I had to remove all my previous .NET installations and re-install the latest one and reinstall P&ID then it all seemed to work OK.
    Active Member
    02-24-2013 12:39 PM in reply to: kennethmjones
    I have deleted these files:
    But I cannot find the other two files.
    Valued Contributor
    kennethmjones
    02-24-2013 03:30 PM in reply to: ryanmcneil01
    its probably a good thing you can't find them since he is saying you should delete them anyway.
    what is the latest version of .NET that you have on your machine I wonder?
    I have .NET Framework 4 extended and the.NT framework 4 client pack and it works fine. before I installed AC i had all kinds of other .NET nonsense installed and ACAD had all kind of problems. Thats all I know about this kind of issue.
