• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    Heckmeck
    Table changes format
    378 Views, 1 Replies
    04-24-2012 12:41 AM
    Hi Everyone!
    I have a problem with the tables on my drawing.
    I use an excel sheet to change certain cells in the tables.
    In AcadPID I get the message to update the table on my drawing.
    Now, the content of the cell is updated properly, but everytime, the dimensions of my table change completey.
    I have set the table in AcadPID to "Format Locked" but still my table changes.
    What can I do here?
    Thanks and best regards!
    Please use plain text.
    Valued Contributor
    Heckmeck
    Re: Table changes format
    10-25-2012 02:43 AM in reply to: Heckmeck
    Is there no one who has the same problem?
    I would appreciate, If some of the developers here could try it out, to see if it is a general problem.
    Thanks in advance!
    Edit:  Deleted all existing tables and their connections, set up everything again, now it's working as it should!
    Think it happens if you replace exisiting data connections.
