• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    adelgado
    TAG ANNOTATION CONTENT LOOSES WHEN SAVING ONLY ON SCREEN
    247 Views, 6 Replies
    02-15-2012 03:41 AM
    Hello I am using Plant3D P&ID 2011,
    I have a problem with Tag Annotation in different situations.
    The first is that Tag anotation value disapears on screen, but when I go to edit the tag it automaticly appears. But then I save the drawing and sometimes I open drawing again and the problem appears again.
    The second problem with Tags is that sometiemes I cannot define a value in a Line number, Plant P&ID do not anything, and trying it until the trird or fourth time, it gets the number i enter and then it works.
    The third problem is that sometimes tags of different inline elements change its Line number independently of Line number where they are when I open drawing after saving it.
    Anyone knows what could be the problem?
    Thank you to all
    ______________________________
    TERMISA ENERGIA S.A.
    http:\\www.termisa.es
    Please use plain text.
    Product Support
    Re: TAG ANNOTATION CONTENT LOOSES WHEN SAVING ONLY ON SCREEN
    02-22-2012 05:35 AM in reply to: adelgado
    The first things to try is to delete the local data cache by running the PnPLocalDataCachePurger.exe. This utility is located in the install directory of the product.
    Once you have done that you should audit the project.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    adelgado
    02-23-2012 01:05 AM in reply to: adelgado
    Hello Dan,
    After using the PnPLocalDataCachePurger.exe, Plant3D freezes on welcome screen and it doesn't works.
    How can I solve it?
    Thank you
    Product Support
    02-23-2012 01:44 AM in reply to: adelgado
    I would not normally expect this to happen after running the utility.
    Have you tried re-booting the machine? I have seen this from time to time on my machine and re-booting tends to fix it.
    If that doesn't help let me know and I will provide some more suggestions.
    Dan
    Dan Scales
    Autodesk, Inc.
    adelgado
    02-23-2012 02:24 AM in reply to: adelgado
    I have test the same procedure on anther computer with Plant and did not happen the Freezing error.
    But now the problem of freezing welcome screen on the previous computer is the main problem.
    Aslo I test in that computer with another windows user account and it works and the welcome screen doesn't freeze, but the normal user continues freezing.
    Please give me a solution so now we are stopped.
    Thank  you very much!
    Product Support
    02-23-2012 03:59 AM in reply to: adelgado
    I have sent you an email through the support system explaining how to trigger the secondary installer.
    Dan
    Dan Scales
    Autodesk, Inc.
    adelgado
    02-26-2012 11:48 PM in reply to: DanScales
    Hi Dan,
    I just solved user welcome screen freezing problem.
    Meanwhile TAG anotation continous with problem but it is a random problem. I think huge problem is that it changes also the check valves direction automaticly when I reopen the drawing file.
    I am working in a Local project.
    Thank you
