• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Distinguished Contributor
    Style questions
    337 Views, 4 Replies
    03-28-2007 06:44 AM
    Are the "Graphical Class Styles" in the Project setup synonymous with an AutoCAD block and some of it's properties?
    If I want to add some of my own symbols, is there a utility to migrate them into this format?
    How are "Class Property Settings" and "Graphical Class Styles" related?
    When I have in the "Graphical Class Styles" an endline for join type, is it suppose to add it to the end of a line or break the line and erase the segment that does not belong?
    I've been through the help file and I don't see a clear explanation (my opinion) or answer to my questions.
    Any help from beta testers or Autodesk on these?
    Please use plain text.
    *Jester
    Re: Style questions
    03-29-2007 05:31 AM in reply to: cawaugh
    This is how I think it might work.
    Draw or insert a block in a drawing containing your custom blocks.
    for example Pump1, save the drawing
    Open PID and a project and a dwg belonging to that project.
    Open project properties by right clicking the project.
    Goto Graphical Styles and pick the class to use as a basis (Pump - General),
    pick New
    New Graphical Style , Continue
    In Graphical Style edit set the layer, colour etc and select the right block
    in Symbol Details part
    Set scale etc
    OK
    In Project Setup
    Create Tool
    -> you get a messy image of your new symbol somewhere in the very end of the
    Tool Palette, drag it to the right location.
    Apply
    Test
    This is roughly how I created b a custom pump block to my project. To create
    your own class and its properties is an another story...
    J.
    wrote in message news:5533308@discussion.autodesk.com...
    into this format?
    Re: Style questions
    03-29-2007 05:44 AM in reply to: cawaugh
    Thanks for the response. I have all that down pat but I need a better clarification on questions 1 & 3. It's pretty interesting how all this is done but I would like to have a more thorough understanding of the relationships, how to set up blocks to work properly with the this program, etc. It seems that there needs to be a certain amount of intelligence (dynamic wise) to make them function properly, breaking lines, etc.
    *Jorge Lopez
    Re: Style questions
    03-29-2007 09:28 PM in reply to: cawaugh
    If you are familiar with ObjectARX, then you will understand the attached
    diagram that illustrates the relationship between the AcPpAsset custom
    entity, the AcPpAssetStyle, and finally the AcDbBlockTableRecord.
    Sort of. A Graphical Class Style corresponds to an AcPpAssetStyle class
    instance. This is a non-graphical object in the DWG file (stored in a
    dictionary within the NamedObjectsDictionary) that is used to define how an
    AcPpAsset (the custom entity placed in modelspace) is displayed. The style
    contains the color, layer, linestyle, linescale, etc and in addition it
    stores a link to the block containing the geometry to be displayed by the
    custom entity (aka. AcPpAsset).
    What you place from the tool palette into modelspace in a custom entity of
    type AcPpAsset. This custom entity fetches its display properties from the
    style (AcPpAssetStyle) it is associated to and the style points to the block
    definition where the geometry is stored. When the custom entity goes to
    display itself, it draws all the entities in that block definition using the
    other properties stored on the style (color, layer, etc).
    Use the project manager UI to make a new style. Then edit the style to point
    it to the DWG and specific block definition you want to use for it. There is
    even a button in the UI to create an icon on the tool palette so you can
    drag-n-drop your item from the tool palette.
    Class Property Settings is related to the project database schema. For
    example, a GateVale has properties X, Y, and Z. Think of it as the columns
    you see in the Data Manager for a given class type.
    Graphical Class Styles define how a class is displayed in the DWG. For
    example, a GateValve goes on layer A and is green.
    The join type defines the expected behavior but it can be overridden by how
    the item is used. For example, you can drop inline items out in space and
    then draw lines from either end in effect making it an end-line asset. Most
    of the behavior is defined by the class name itself. For example, if the
    class is a "Reducer" then we know it should break the line when placed. I do
    not believe we have documented all the specific classes we internally
    capture for specific behavior. If you have a specific need, ask and I will
    see what I can do for you.
    - Jorge
    into this format?
    Re: Style questions
    03-30-2007 04:40 AM in reply to: cawaugh
    That explains a lot.
    It would be great to have an explanation in laymen's terms for the novice in the help file somewhere but I understand your answer.
    Thanks!
